I have a 2002 Winnebago Adventurer. No matter what I turn my control to, the air blows out the defrost vents and floor vents. I looked inside the front compartment but didn’t find any vacuum tubes. An...
Not sure with the F53, but with some vehicles low Freon in the AC system will also cause a default to the def and floor. Is the air coming out as cold as you would expect for the AC? If not a recharge may cure the problem.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
