Gdetrailer
Apr 10, 2014Explorer III
Have my doubts that the replaced fuse was bad..
Fuses tend to fail when there IS a problem.
Is it the fan motor not working or is it the compressor not working (you get warm air from the fan).
If fan is working but getting warm air, pretty good chance with the age of the RV that you have a bad clutch coil on the AC compressor if the fuse is blown..
A good AC shop should be able to check the current draw of the clutch coil.
If new fuse is not blown and you are getting warm air then you have a worn AC clutch. This often can be fixed buy removing the inside of the clutch and removing a shim or two. This is a common problem when the AC clutch wears a bit the magnetic gap widens too far and the clutch no longer catches. You can check to see if the AC compressor turns on while running, just have engine running and a helper turn on the AC and what to see if the center of the compressor clutch starts spinning..
Additionally no clutch but the fuse is good you could be low on refrigerant and or have a bad pressure switch..
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
