MrWizard
Aug 04, 2014Moderator
DC buck converter ..20v 2amp.. with LCD display.. BOOST?
easy in panel mounting, same dimensions as most digital panel meters
$39.38 on Amazon
buck converter
Dimension: 79mm*42mm*26mm (L*W*H)
Input voltage range : 4.5-23V ( please make sure input voltage below 23V)
Output voltage range : 0V-20.0V( Step down mode, input voltage must be higher than 3V), the control button can fast display 2 sets data.
Output current :0-2.00A; Output power : Max 40W
Ripple frequency: About 330 KHz; Ripple peak to peak value : 50mv (typical value)
$39.38 on Amazon
buck converter
