Question- DC charging? I'm upgrading my converter from 45 Amps to 60 Amps- DC- Do I need to change any of the wiring going to the Battery IE. larger wire? Or just to the panel? Will it work with the o...
You can leave the wiring as is, since #8 AWG is good for a 55amper.
But what is the reason to go to 60? What model is the old converter and what would be the model of the 60?
Adding a second battery will not make any difference except it will take twice as long to recharge the bank---but also you get more time to discharge, which is good. In fact you get more than twice the discharge time at the same loads, due to the magic of Peukert Effect.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
