DutchmenSport wrote:
As stated above, it sound like your in-line fuse (near where the battery connects) has blown. These are made different ways. Some use push-button resets, others use the little flat fuse used in automobiles, and some use a fixed square box looking thing that, when it blows, you have to replace the entire thing. I've had all 3 types on my campers. Check for a fuse on the wires connected to the battery. Should be quite obvious if one is there. And there SHOULD be one there.
I'll look further after it stops pouring down rain. Thank you. I know that there has to be an interrupt somewhere but I'm ****** if I have been able to find it as of yet.
