BFL13 wrote:
Yes, thanks. I will see how it goes first. It is more like 12 ft one way, but the 7-pin charging wires are more like #10 or 12, so amps will suffer. It is a Truck Camper and camper batts are near the front of the truck bed, so closer. I get 15 amps on the 7-pin now to the camper batt (at first, then it tapers)
The whole point of a DC-DC charger is NOT HAVE TO WORRY ABOUT VOLTAGE DROP ! The charger should be as close as practical to the house battery. The limiting factor will be the fuse that is powering the 7-pin charge wire.
BFL13 wrote:
My purpose is not to get more amps (but that would be nice), but to not have the two types of batteries "mixed", which might not even be an issue either. I just don't want to mix them and that's that.
This is even MORE important if you are running different battery chemistries.
