time2roll
Jul 26, 2020Nomad
Assuming you are trying to run on battery power only... measure the battery voltage. Then check the voltage along the path to the stack of 12v fuses. Somewhere you will find the voltage drops to zero. Tighten, clean, adjust, repair, replace the issue at that point. BTW if battery voltage is less than 12.4 get a charger on it.
Otherwise if you are plugged in you should see 120v at all the branch circuit breakers. You should also have about 13.6 volts DC coming out of the converter, 13.6 VDC at the stack of 12v fuses, and 13.6 VDC on the battery. Again poke around with your voltmeter to find the point of issue if power is not getting to all components.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
