BFL13
Jul 26, 2020Explorer II
Is there a "battery disconnect switch" that got switched to "open" in all the excitement?
Sometimes these are mounted inside near the door.
Not everything gets shut off by that switch (LP alarm, eg) so the hydraulic pump must not be on it either if that is the problem here. Also that pump working means your "battery fuse" (or DC CB) close to the battery must be ok.
Only thing after the battery fuse and the DC panel is the battery disconnect switch, so suspect that.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
