BFL13
Jul 26, 2020Explorer II
No such switch. Whole idea is for the converter when on shore power to recharge and then maintain the battery, so you don't want the battery disconnected.
On our old 5er, the battery disconnect switch was at the kitchen counter and was a push pull knob. Wife kept bumping it without knowing she did it and that would kill the 12v. :)
Some have a big red switch handle but it is hard to tell which way is open and which way is closed. Same with those rocker switch types seen in some Class As over the door. (they put two same looking rockers there so first you have to guess which is the house battery disconnect, then guess which way is open)
Some people call those a "salesman switch", can't remember why.
EDIT--sounds like a typical idiotic RV layout for the battery only reversed from the usual. If possible, move the battery to the front cargo bay like many 5ers have theirs, so it is close to the converter and DC fuse panel in that 5er. Saves voltage drop by using short wire runs. Many RVs seem to be based on the idea of using miles of thin wire instead, so the battery is at the other end of the RV from the converter. :(
