ajriding
Jul 26, 2020Explorer II
This should work (plugging into the shoreline extension plug) BUT BUT BUT you must flip the circuit breaker to the converter/charger to off, and also switch the breaker to the refrigerator to off (or just unplug it from the outlet), and do not try to run the Air conditioner.
The battery can supply electric to the circuit breaker panel just fine, the issue is that there are things that need more power than the inverter/battery can supply.
I do not think there is a feedback loop created with the battery supplying the charger that is trying to supply the battery, someone correct me if wrong. If older tech, then the charger is a big transformer, so will not short or anything, but if all new electronics then I do not know details how it would work.
The battery is a big absorber of electrical currents so should handle what is thrown at it in this case.
To do this safely you need to isolate the outlets that can be used with the inverter from the outlets and devices that cannot be run or that you do not want to run off the inverter. You need a switch that chooses A or B where A is shoreline and B is inverter. B will just supply the chosen outlets while A will supply everything (both the chosen outlets and the things chosen not to run off inverter).
Of just keep the inverter out of the electrical system, run an extension cord from it into a power strip and plug in there.
