time2roll
Jul 28, 2020Nomad
OK it looks mostly OEM but I still suggest you check the amp rating vs that small wire coming off the top.
Glad to hear it is fixed but I am not sure it really is. Check the amp rating of the converter and compare to the breaker that opened. I suspect it might be underrated. Wire might be underrated too if the converter was replaced with a higher output. Breaker rating should be 20% greater than the converter max output and not larger than the wire ampacity.
