I'm having an issue with my DC power and I began to notice the issue when I got an error message on my frig. I am currently living in a RV park and connected to power. Then the lights started going di...
Turn battery charger. See how bright the lights are. Then turn off the breaker to the converter to see if lights dim down right away. If they do the converter is outputting. Turn breaker back on. If they do not get bright when converter breaker is turned back on, your converter is not working properly. It could be fuses in the converter or the main fuse in the DC section is blown. You should be tested for voltage and not visually.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
