JiminDenver wrote:
I had the roof air removed and will switch to this if the window A/C isn't enough.
click
I have a dual hose portable. It is the largest one made for a 15 amp outlet and is rated at 12.5K BTU heating and 13K BTU cooling. Single hose portables are a joke but not this thing. If connecting the hosed to a window, they can get quite bulky and require the unit to be 6-8 inches away from the wall. If installing in an RV, I'd try and mount right against the wall with two holes for the hoses straight out through the wall. I use mine in a shop office
