pianotuna wrote:
Hi all,
I finally have the dc to DC 20 amp Renogy installed.
It works, but not quite as I expected.
It appears to not "like" solar much--cutting way back on amps, even though the dip switches are set to 14.7 volts output on the Renogy.
I do have manual control of the solenoid that feeds the Renogy.
It was distinctly NOT an easy install. The only place for it was under the passengers seat. I added some spacers under the unit as it appears there is an additional heat sink on the bottom of the unit.
Installation was with #8 wire.
I did turn the Renogy on after a night of boondocking where the "house" bank got down to 12.3 volts. At idle, charging was about 10 amps. At highway speed that went up to about 19 amps. I did not have a long drive that day.
I can still do a "poor man's" boost system should the starter battery ever be low.
The Renogy did stop the energy drain from the Telcom "house" jars to the engine. On the other hand, I could have done that with the original upgrade which gave me a dual charging path to the "house" bank--with manually controlled solenoids.
I think this may be the last "tech" upgrade I do.
19 amps driving that not bad at all from a 20 amp setup. I wonder if the tapering amprage is because your using LA batteries who taper off amps as they charge and since you have solar going the renogy is getting a higher voltage back and tapering off. everyone I have seen tht uses them so far is using them with LFP batteries.
Steve
