Land,
You say the interior lights were still good. Did they stay good when you tried to crank? If yes, the problem is not your isolator.
Better information helps a lot. It may be that what you seem to have is either an unidentified parasitic load on the chassis battery or a just plain bad chassis battery. This is not all that rare. Most new vehicles have a parasitic load in the engine and body control computers that have been common since the late 80s.
Are you sure you did not leave the parking lights or the cab light on?
Next -
You could pull the battery out and schlep it to a car parts place that will test it.
Or
Get a meter (the cheap/free at Hazard Fright will do) and do a short test. Let the coach sit for a day and then put the meter on the engine battery. Now, turn on the head lights. If you look at the top of the battery, it will say RC=100 or something. That is how many minutes you can leave the headlights on and still have starting power.
If you wait half that many minutes and the battery voltage is still above 12.0, the battery is good.
If you plan to keep that battery (as in it passed), then attach two wires to a small light bulb. Remove a battery connection and put the light in series with it. It may light just enough that you can see it with your hand wrapped around it. That is the afore mentioned computer quiescent load. If it is brighter than that, start searching. Have a friend watch while you pull fuses from the chassis fuse panel. If one makes it go dim, you have found the problem.
Good Hunting
Matt
