landlordy's avatar
landlordy
Dead Battery Question
I have a small 20-foot Born Free with Freedom 10 charger/inverter. I left it parked for two nights at a friend's house. The inverter was on, and the only thing plugged in was a low consumption Engel fridge. The battery was absolutely completely dead when I went to start it this morning.
My question is, if I run the inverter on accident for too long, shouldn't the battery isolator protect the front battery?
  • Hey Matt,
    The Freedom 10 is definitely connected to the house bank. The odd thing is that the fridge and house lights were working fine. What is the best way to test the battery isolator?
    Thanks a lot.
    LL
  • "The inverter was on, and the only thing plugged in was a low consumption Engel fridge."
    You misunderstood the consumption of the fridge, and draining the battery completely down has greatly harmed the battery. Running half the time at 3 amps or so for two full days would use about 80 amp hours just for the fridge. Far more than 99% of all RV single batteries could handle.
  • Well Land,
    The isolator should have maintained the separation of the chassis (engine) and coach (house) batteries, but I guess it did not. Even if the inverter was installed by Born Free, that does not mean it was done right. But as for dead, I do not know of an electric refrigerator that will not do harm to any normal house bank in two days.
    The Engel coolers that I have known still have a battery drain that is a lot like leaving the parking lights on. Not many vehicles can do that for two days.
    I suggest that:
    You determine that the Freedom 10 I connected to the house bank.
    You test the isolator to determine if it is functioning properly.
    If the isolator is a BIRD or CDsolenoid, the device can stick or the contacts weld and then you have your case. In the boat business that the depression killed, I used to replace more than a few of the contactor kind isolators in any season.
    Matt
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
