j-d
Apr 30, 2016Explorer II
The emergency start relay/solenoid is usually under the hood. It allows you to use the coach (aka "house") battery to give yourself a jump start if the chassis battery goes dead out on a campsite.
Doug is referring to the battery that supplies the living quarters. It'll be in a compartment like your other outside storage. Look for another relay/solenoid there, near the battery/batteries. Should look about like this
. Can be fuses etc around it. Controlled by a switch inside the coach. Our switch is by the door. It is ON, right? Battery charged, right?
. Can be fuses etc around it. Controlled by a switch inside the coach. Our switch is by the door. It is ON, right? Battery charged, right?About Technical Issues
