dougrainer
Nov 03, 2013Nomad
If it is just a standard screw hole and the only one. The BEST fix is simple and will not leak. You drill out the hole to 3/8 inch and install a standard rubber Monitor tank sending unit. THAT will permanently seal the hole and fix the problem. Eternabond, while good stuff will NOT seal most tanks and is NOT designed to handle the flexing and the pressure from liquids. Doug
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
