ktmrfs
Nov 22, 2013Explorer II
DavinD wrote:wa8yxm wrote:
One thing ... A proper plastic weld is .. Well going to last a long, long, time.
I hope so, frankly I'm concerned about what else they'll mess up while replacing it. Given that it's in a section where it will rub on the frame, do you still think it will last?
If they spin weld a plastic patch on, it will be as strong as the original material. Spin welding polyethelyne is a very common industry practice to attach fittings to tanks and it holds up very well. Basically it is a friction process that creates enough friction to melt the surface of both parts as one is spinning and when they stop it quickly cools and creates a welded joint just like it was molded.
I wouldn't be suprised if the fill tube and vent tube were spin welded onto the OEM tank. They often start with a fixed shape tank and each user then spin welds on the various fittings as needed for the specific application rather than trying to mold them into the tank.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
