craftyfox's avatar
craftyfox
Decal Removal
Hubby has taken off the large decals that were covering the lower half of our cargo doors and we are left with half the door white and the other half not so white. Does anyone have any suggestions for brightening up the area that was exposed to the weather? Maybe bleach? I've read where Fusion paint was used to bring yellowed trim, vents, etc., back to white but wonder how it would work on such a large area.
Moved to Tech Issues forum from DIY.
  • You will not be able to get rid of the fade lines. That is the effect of the UV exposure. Over time as the newly exposed area now gets the same exposure it will lesson the effect but its not in the top layer of clearcoat so the buffing and waxing will only help if the exposed area is oxidized. The pigments in the base coat and fiberglass fade and the only easy way to fix it is a larger decal over the same area otherwise you can repaint or wrap the unit.
    Same thing happens to cars if you a buy a new car you can remove the decals in the first year with virtually no shadowing.
    This is also a common problem if you get your vehicle wrapped for marketing and then remove the wrap after 2 years any spots not covered by the wrap will have faded and cause the uneven shadowing in the paint.
  • RV CONUS wrote:
    Try Bar Keepers Friend, worked for mine; as well as other stains.
    I removed the peeling Bounder stickers on our MH. Used Bar Keepers Friend and scotch bright pad, equal to "0" steel wool. If you know where to look and look hard enough you can see a faint outline of the old sticker. Most people will never notice though. This is on fiber glass not a painted surface.
    I actually used the scotch bright and Bar Keepers Friend on the whole rig before applying Zep wet look floor polish.
  • Go to a boat/marine shop and buy some 3M restorer. It will take the oxidation on the exposed parts aaway.
  • Try Bar Keepers Friend, worked for mine; as well as other stains.
  • Look on the internet for this: "Buff Magic". I used it on my 13 year old rig last year and man what a difference it made. Follow the directions on the can. best if you use a 4" buffer, and work in a small area.Buff the area until the paste is all used, like you can't see it any more. And then wipe it off with a clean towel.
  • Maybe rubbing compound or one of those light cleaning kits go slow
    GOOD LUCK
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
