atp20's avatar
atp20
Deep Cycle Battery Charging From Alternator
Hello,
May I ask for advice regarding charging deep cycle batteries from the alternator? I have read older threads, and understand opinions vary.
The previous two 100Ah deep cycle AGM coach batteries each failed in well under two years of intermittent use in my 2003 Sprinter Class B.
Would non-AGM deep cycle batteries last longer? AGMs have been said to be sensitive to overcharging. Any battery recommendations? Maintenance-free would be preferred because of awkward battery access.
Do I need to look into some sort of smart charger, alternator-to-battery charger, or inverter/charger setup? I'd like to keep things simple.
Would installing a second coach battery affect the situation?
The RV is used as a daily driver and for long distance trips, boondocking mostly. When traveling, the principal load consists of two refrigerators, drawing 2.5A each when active, plus a high power blender that draws about 95A (12v) through a 2kw inverter for two minutes a day. The coach battery is located under the rear floor, about 20' from the alternator. Not sure of the connecting wire size, which runs through an isolator and 50A breaker. The 120A(?) alternator charges at 14.4 volts when the battery is full.
Thank you. Any advice would be appreciated.
Jerry S
2003 Freightliner Sprinter Class B
S Florida
  • RoyB's avatar
    RoyB
    Explorer II
    pianotuna wrote:
    Hi,
    For maintenance between trips 60 to 150 watts of solar per 100 amp-hours of storage.
    For charging while trundling down the road, look at a DC to DC voltage boost device. Expect sticker shock.
    Another route would be an inverter powered from the alternator that is sufficiently large enough to power the converter, or a stand alone battery charger.
    I've spend more on generator maintenance than on my modest solar installation. My costs were $5.50 per watt in 2006. On a DIY it is possible to get to under $2 per watt.
    Don - That was the first thing I did - was to check with AMAZON on how much the CTEK 250s cost... Definitely a sticker shock hehe... Sounds like an interesting thing to have for us OFF-GRID guys...
    Roy Ken
  • Hi,
  • MEXICOWANDERER wrote:
    Those batteries were perpetually undercharged. There are too many clues for this to not be fact.
    Maybe not.
    IF....they are being hit with 14.4 volts every day for an hour or more.....then they might be getting OVER CHARGED if they aren't used during that time.
    Some resting voltage measurements need to be made.
    You might be much better off disconnecting them from the alternator system during the "daily driver" periods.
    THEN....there is the ridiculous drain from that blender.
    Things can be mashed and shredded without electricity.
    I suggest that you STOP using the blender....and any other high current device that may be present too, like a hair dryer maybe.
    OR....that you keep doing what you are doing and buy new batteries every 2 years.
    There's no way your vehicle's alternator is going to properly and fully charge your deep cycle batteries on it's own. The solution is a purpose designed DC > DC charger, one being the CTEK250SA that will ensure proper charging of those deep cycle batteries as you drive.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    As Mex Says. ALL BATTERIES are sensitive to over (and I might add UNDER) charging. For best life they need PROPER charging.
    AGM and other "Maintenance free" designs the issue is if you should boil them hard enough that they vent vapor. there is no way to replace the lost liquid.
    Now they are designed to MINIMIZE this (not vent less they absolutely have to) to recombine the oxygen and hydrogen produced back into water and thus self water. But there is a limit to this ability.. IF they vent. it's lost and gone forever.
    FLooded wet cells you can always add distilled water.
  • Ivylog's avatar
    Ivylog
    Explorer III
    14.4V is not to high for AGMs.l and it sounds like yours never gets fully charged..:to small a charging wire from the alternator. How do you charge them when on shore power?
    Even though I have a large 200A alternator on my DP, I do not use it to bulk charge my house batteries...150+ amps x 4+ hours cannot be good on the alternator without extra cooling. I run my generator before leaving and then let the alternator finish charging at 50 amps or less. Like the other posters I think you need a small generator or a better 129V charger. I get 10+ years out of my oversized AGM house battery bank.
  • Tough to beat a HF 2 cycle gen and 36 amp charger for the money 5 hours of charging for 2 dollars in fuel. 30+ amps of solar isn't cheap.
    Intermittent, The RV is used as a daily driver and for long distance trips, boondocking mostly. The coach battery is located under the rear floor, about 20' from the alternator. Not sure of the connecting wire size, which runs through an isolator and 50A breaker.
    All batteries are sensitive to abuse.
    This is my bet...abusing a different style of battery likely won't change the outcome.
  • atp20 wrote:
    Hello,
    Is you alternator the only charging source?
    Pretty much impossible to get from 80% charged to 100% charged in less than 3.5 hours. Ideally if you were to drive this 3.5 hours, the vehicle's voltage regulator would ideally be holding voltage in the 14.4v range and this would also be reaching distant house battery, over thick copper cable/circuit between alternator and house battery.
    BUt your vehicle is extremely unlikely to hold 14.4v after 3.5 hours driving, meaning they are not recharging as fast as they could/should.
    Do not check voltage once after engine starting and expect this is the voltage the vehicle's voltage regulator always allows.
    Intermittent use....Put a solar panel on the roof, it will have the time to get them full and keep them full between intermittent uses, but get a solar controller with a battery temp sensor for South Florida summers.
    Getting the AGMs full between intermittent use is paramount to longevity. If you fully charge them from the grid, and then fully disconnect them from all loads, they should not self discharge much at all. as low as 1.5% and as high as 5% per month, but higher in hotter ambient temps.
    If the only charging source continues to be only the alternator in intermittent use, 2 years is all you can expect from any lead acid battery no matter how high its perceived or actual retail value.
    Flooded deep cycle 6v jars might wake back up some from an extended equalization charge upto 16.2v after such abuse. But perhaps not.
    How you get your batteries full is up to you, but if you want more than 2 years from them you have to gt them full regularly, and hopefuly promptly after any significant discharge
  • Intermittent, The RV is used as a daily driver and for long distance trips, boondocking mostly. The coach battery is located under the rear floor, about 20' from the alternator. Not sure of the connecting wire size, which runs through an isolator and 50A breaker.
    First would be full one gauge AWG wire throughout the charging system. Eighty amp breakers to all batteries. A small generator and fixed voltage charger set for 14.4 volts that can run for 4 hours on a tank of fuel and deliver 40 amps.
    My setup is larger. 4 L-16 batteries. A 400 amp 28 volt Niehoff Batteries 4/0 gauge to the L-16's and a 40 DC amp 120 volt 28 volt charger.
    When your AGM batteries are finished charging they will automatically accept ONE HALF AMP EACH or one full amp both batteries. This is accurate and reliable indicator showing your batteries are full. If you shut down the charging before the amperage drops to one amp you are undercharging the batteries and the short lifespan screams proof of this. By getting a tiny generator and power supply then letting it run out of has finish charging every day you'll greatly improve battery life. That and spend the money for the wiring upgrade. What I just wrote is not guesswork :)
