MEXICOWANDERER wrote:
Batteries discharge differently. Look at the FINISHING VOLTAGE of a reserve capacity test.
"Can't be overdrawn - still have checks left" ineptitude.
yes dead 10.5
100 hr test
ridiculous 1 amp drawn ?
not useful in real life too you or me
i can pull 20 amps easy at night for several hours
and 8-9amps for the fridge off/on all night long
if a battery could do 25amps for 180 minutes aka 3 hours
then (2) could do 50 amps for the same time span
or do 25 for 6 hrs or more
this is info that is easier to compare and compute
its a constant draw not a variable draw 'per battery size' over a fixed time
neither system is perfect
but you can't compare batteries, using two different rating systems
