dougrainer
Oct 03, 2017Nomad
Almot wrote:
Er...it's propane stove - aided by the owner - that is a safety hazard :). Don't blame the detector, it just died, that's it.
Doxie - I think those stoves that I've seen, had no regulator inside, only valves. Though there is safety push/lock feature in the oven valve.
There is such thing as an (optional) excess flow valve that would shut the line off when there is exactly a leak - detected by abrupt increase in propane flow. It comes in both low and high pressure. I installed one before my cat heater, since this is the only propane item that could run with me sleeping. But I doubt excess flow valve would work in the case described above.
RV LP Range/Ovens HAVE a LP regulator that drops the pressure from 11.5 to 10 wc. They run at 10 inches WC pressure NOT at the 11.5 all other LP appliances run at. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
