pauldub
Dec 09, 2018Explorer
smthbros wrote:DownTheAvenue wrote:bid_time wrote:
Just buy a dehumifier. Plug it in, turn the dial to the desired level, done - problem solved.
X2
And the plus is you would gain more dehumidification with less use of energy.
I have doubt about this claim of using less energy, but have not performed the calculations. Have you?
It's really pretty obvious without calculations. The A/C is removing moisture and hot air, then the lost hot air has to be replaced by running the heater. A dehumidifier is an A/C that doesn't exhaust the warm air to the outdoors.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
