How did I wire 24 2-volt 1,625 amp hours jars?
The CORRECT ANSWER is you establish a KNOWN proved-good standard for a series or parallel set of batteries.
With a carbon pile load tester using algebra when necessary, test additive battery additions. I tested 24 volts with a thousand amp load. You do not have an eleven ton bank. So both voltage and amperage tests are far less powerful. You do not test with a @#$%^! Kelvin Meter because the connections are REACTIVE.
Testing milliohms is insane. A comedy. A misconnection can go from 3-milli-ohms to 40 megohms in 2 seconds flat. Got a question LOAD the @#$%^! bank with a high inverter load and MEASURE THE VOLTAGE ACROSS EACH 6 cell BATTERY. You will find the lazy red headed stepson in 10 seconds flat.
SHEESH!
