Chum lee wrote:
Nowhere did I tell you, or anyone else what they should or should not add/remove from/to their propane system. As far as I'm concerned, it's your vehicle (home) and your choice.
You DID imply that it should not be removed by telling "stories" of how it "could" be more dangerous. Therefore you DID "TELL" the OP to not remove the solenoid.
Chum lee wrote:
Clearly, you haven't thought about this at all. I'm not talking about fuel injectors spraying atomized fuel on/into a hot engine. I'm talking about a running fuel pump with ruptured fuel lines pumping liquid fuel at 50 psi into a crash zone. Do you get the difference?
Clearly, YOU do not "understand" what happens to gasoline when it "sprays" out of a "ruptured line" and hits hot items like hot engine and exhaust systems, especially the cat converter which operates in the thousands of degrees F zone. Under the hood fires caused by ruptured fuel do indeed happen.. Had a close call myself with a brand new just delivered 90's "K" car which ended up in a fire ball.. A faulty fuel line under the hood..
Chum lee wrote:
In a residential application, (as you have stated at .5psi) dumping gaseous fuel (propane/natural gas/whatever) into a large area is going to take a lot of time to reach the stochiometric explosive point. In the confines of an RV, not so. Do you GET that? I don't think so.
Takes VOLUME, lots of VOLUME to reach stochiometric explosive point. It is for that reason, there IS an "odorant" that must be added to propane and natural gas called
Ethyl Mercaptan. Ethyl Mercaptan is the extremely pungent and highly offensive potent odor that could darn near wake the sleeping dead.
From website above..
"The odds are good that you haven’t heard of Ethyl Mercaptan. But it’s just as likely that you’ve smelled its unpleasant presence before. Ethyl Mercaptan is what makes propane gas smell. It’s an additive that is combined with liquified petroleum gas, or LPG, to alert users of a leak.
What does propane gas smell like?
Depending on the makeup of your olfactory senses, Ethyl Mercaptan most often is reported to smell like rotten eggs or sometimes rotten cabbage. Some also say it has a strong garlic, or skunk-like, smell.
Although the smell of Ethyl Mercaptan might be among the worst in the world, it has proven to be an effective tool in alerting propane users to a problem –and giving them the time they need to ensure their safety."Chum lee wrote:
Look Mr. Gdetrailer, I have no interest in getting into a pissing match with you. One question for you though. Where did you get your engineering degrees? It's a rhetorical question. (I really don't care and don't bother answering, . . . I already know the answer) This is why I rarely post here anymore.
Chum lee
If you had an "engineering degree" then you would understand how this (propane) works without using scare tactics like "what if the flame gets blown out by the wind".. That is what what your nose, Ethyl Mercaptan and propane detector is for. Having some automatic valve being shut by the propane detector really isn't needed and very few RVs have that system.
And by the way, gas detectors like the LP gas ones use in RVs can wear out, should be replaced periodically and they tend to falsely trip on most any "explosive" gas, hairsprays, deodorants in spray form, even human or animal flatulence.. They don't just detect LP gas, they detect any explosive gas.
And for the record, I never told anyone to chuck the LP gas detector, but the automatic gas valve is optional..
