anon125's avatar
anon125
dewinterizing and sanitizing check list.
is there such a check list?
and if we have the hose thingy on the water pump for dewinterizing can we use that to get the bleach solution into the MH?
will the water tank have the antifreeze in it or just the pipes?
if empty it will need a very good clean!
the pink stuff has been in the MH for 3 years.
thanks all
  • that pick up tube will pick up any liquid, antifreeze, chlorine solution, etc. and using it means you do NOT have to put antifreeze into your fresh water tank, just drain it as a little water left in the bottom won't do any damage.
    bumpy
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
