Mont_G_J's avatar
Mont_G_J
Dexter Axle wheel studs
My 5th wheel has 5200lb Dexter axles with 6 wheel studs that are
1/2 x 20. On one occasion all six studs broke and I lost the right rear wheel. On three other separate occasions, I have had one or two broken studs that are always on the rear wheels. I check the 120 lb torque often and have used two different torque wrenches.
My question is, does anyone know if there is a harder or stronger grade stud available for Dexter axles?
    Shadow Catcher wrote:
    Are you using a torque wrench?
    :R
  • jetcare wrote:
    My personal experience is that the lug nut torque specification is 90-120 foot pounds and I find that 90-100 feels right and 120 seems too tight. Just my opinion. This is for steel wheels. Dexter says the bolts are already Grade 8 quality. I realize this did not answer your question.
    Dexter PDF File
    I've been torquing mine to 100#. That's with aluminum wheels
  • My personal experience is that the lug nut torque specification is 90-120 foot pounds and I find that 90-100 feels right and 120 seems too tight. Just my opinion. This is for steel wheels. Dexter says the bolts are already Grade 8 quality. I realize this did not answer your question.
    Dexter PDF File
  • Are you using a torque wrench? I use antiseize and the lubricated stud torque value and I have never broken a stud.
    For the studsTorque valuses on my Dexter axle that is about 90 ft-lbs
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Sep 02, 2025
