Most newer trailers come with Dexter EasyLube Axles. These are supposed to simplify the requirement to lube the bearings every 12 months by applying grease to the Zerk fitting. However, most "experts"...
I bought a new tandem axel trailer, and one of the tires was wearing one side of the tread. I found that U-bolts on that end of the axel had not been tightened to the leaf spring and had slid a little on the spring, and had worn those U-bolts. I put new U-bolts on it, and made sure they were tight. That was 10 to 15 years ago, and I'm still using that trailer.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
