MFL
Dec 29, 2018Nomad II
Dexter has been a fairly reputable company for many years. While one size does not fit all, the description from Dexter, for many RV axles sounds about right. Once the hub/bearings are set, about 50 lbs, the castle nut can be loosened, without moving the hub, finger tight, put pin through. If pin is not aligned at finger tight, it should be backed off slightly, until pin goes through.
You are correct, with so many folks doing things differently, seems like more bearing failures could be caused by incompetence, than lack of grease.
Most I've seen have dust plugs, unless removed and forgotten/left out by a previous owner.
Jerry
Jerry
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
