DustyR
Dec 30, 2018Explorer
MFL wrote:
Dexter has been a fairly reputable company for many years. While one size does not fit all, the description from Dexter, for many RV axles sounds about right. Once the hub/bearings are set, about 50 lbs, the castle nut can be loosened, without moving the hub, finger tight, put pin through. If pin is not aligned at finger tight, it should be backed off slightly, until pin goes through.
You are correct, with so many folks doing things differently, seems like more bearing failures could be caused by incompetence, than lack of grease.
Most I've seen have dust plugs, unless removed and forgotten/left out by a previous owner.
Jerry
X-2
This method insures that the bearing/race combo is properly seated in the hub. Better slightly loose than too tight.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
