fj12ryder
Dec 30, 2018Explorer III
Ron3rd wrote:Yes a tight bearing will bind and heat up and go south...but you have no idea what that "mechanic" did. You weren't there, and you're simply speculating, but you sound a lot like "a know-it-all expert mechanic in his mind". You might want to put an "I imagine" in there somewhere.Timeking wrote:
That gives me a bit of assurance. When I first had a TT back in 2007, I paid a mechanic to repack my bearings ... and everyone of them failed. Spent hours and hours pounding all the races out and re-seating. Don't ever want to go through that again.
They all failed because he was a know-it-all expert mechanic in his mind and set the bearings too tight and did not follow the Dexter procedure. A tight bearing will burn up quickly; a slightly loose bearing will not.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
