- DesertboyExplorerThanks guys, Im looking for more threads. I figured those youngsters in the other message boards were not correct, and that's why I asked the question here. If you do run across anymore info on this topic please post it or message me. I feel like I should spend a few hundred more and just get the Honda 2000 and be on the safe side, Im sure it would do the job plus power lights ect.
- JiminDenverExplorer IIFor what those things cost, you can bet they last much longer than 800 hours when taken care of properly. They are king of the hill for a reason.
Running a 5000 BTU air conditioner is easy, starting it depends on the unit, temperature, altitude and the surge ability of the generator. I spent a year finding out which unit used the least so my solar could run it. Starting it requires a battery to give the umph the compressor needs to get going. Getting it going again when the pressure has built up is even harder so you may have to run it full blast so that the compressor doesn't cycle. There is a you tube of someone doing this.
https://www.youtube.com/watch?v=QnsCfRsrevg - SoundGuyExplorer
Desertboy wrote:
I read on another message board that these small Generators only lasted about 800 hours before they needed a rebuild/ Is that true?
I'm sure that would be interesting news to those who live off grid year 'round and claim 10,000 hrs of run time on an EU2000i without a major rebuild is entirely possible. :B - DesertboyExplorerWould the Honda 1000 be enough to operate a 5000 BTU window unit? And one other question, I read on another message board that these small Generators only lasted about 800 hours before they needed a rebuild/ Is that true?
- otrfunExplorer IIThe 3 vs. 7 meter debate aside, I've found the Honda, Yamaha, and Champion generator db ratings generally useful and reflective of realworld performance.
The Champion 3100 is rated at 58 db at 25% load (700 watts). The Honda EU2000i is rated at 53 db at 25% load (400 watt) and 59 db at 100% load (1600 watts). I've had plenty of opportunity to listen to these two generators operating side-by-side under differing loads. Put a 25% load (700 watts) on the Champion 3100 and a 100% load (1600 watts) on the EU2000i and you'll find there is no remarkable difference in sound level (both with eco mode on). Both are still somewhat quiet. However, if you increase the Champion 3100's load to 100% (2800 watts) the sound level goes up significantly. Under 100% load (2800 watts) the Champion 3100's sound level approaches the level of a "quieter" open-frame generator---IMO, approx. 65-66 db.
IMO, advertised db levels are generally useful and reflective of realworld performance as long as the load level is also factored into the db comparison. - robert_at_hondaExplorer
red31 wrote:
Not sure if this is the same Robert @ honda, via Facebook.
".I am looking into this, but on the outset, it may just be a typo/error. I am pretty sure the 7 meters spec is correct, but understand some documents state the distance as 3 meters. When I can confirm, I will give you the straight dope on the actual spec.
By-the-way, are you active on www.rv.net? This discussion has come up in a forum there too, and I'm trying to get a firm answer for them as well.
Thanks! -Robert"
Thanks.
Yes, that's me. Same-same. Stand by and I'll post the definitive answer ASAP.
I work for Honda, but the preceding is my opinion alone.
Robert@Honda - red31ExplorerNot sure if this is the same Robert @ honda, via Facebook.
Thanks! -Robert"
Thanks. - SoundGuyExplorer
JiminDenver wrote:
Side by side testing is the death knell for fudgy advertisers and never appreciated by those that puff out their chest with the but but but mine is better and worth every penny because of it. Yet even when the truth is revealed they will grasp at that advertising so that they can feel good about looking down their nose. They still have more repair centers right, you can always hang your hat on that. lol
LOL indeed ... curious as to why you'd be so worked up about this. :h I'm an EU2000i owner and yeah, I'd like a straight answer from Honda about their noise measurement process but beyond that I can't say I care at all. It is what it is, which as far as I'm concerned is still too much noise for use in an organized campground regardless of how "quiet" Honda or Yamaha or Champion or whomever claim their gensets to be. That's why I went to all the trouble to build a genset noise reduction box that when sitting in the back of my Avalanche's closed cargo compartment does indeed reduce the racket substantially ... but it's not silent, that's for sure. As for "looking down" at anyone who doesn't own a Honda inverter genset you'd have to look elsewhere as I could care less what anyone else chooses to own, yourself included, my only concern being that whatever it is I don't want to hear it. :R - red31Explorer
SCVJeff wrote:
Rather than beat this thing to death, take their DB specs and adapt to the competition distance specs. And move on. Why keep calling people, even at the company that can't even agree.
No adapting needed.
Honda uses the same dB spec for both 9 and 23 feet.
Too many 'home', university, magazine tests that show even at 23', honda is 'optimistic'. - JiminDenverExplorer IIThat's why testing from agencies outside of the companies is important. A universality has nothing to gain by fudging the numbers. Camping life isn't on Hondas marketing team and 23 ft is the industry standard.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 13, 2025
