We are all missing something here. We are all so attuned to 30 amp RV outlets, that is what we are discussing. That is NOT what was said in the first post. Here is what he actually said (edited down to the pertinent lines).
rpetritsch wrote:
When I built the house I had the electrical install a 30amp service in order to connect to a generator. I connected the mh to the outlet.
He did not have a 30 amp RV outlet installed. He had a 30 amp outlet installed to backfeed his house from a generator. (Illegal and dangerous way to do it, but that is another discussion.) Now, whoever wired this up assumed that the generator would be a 240v generator so they wired up the outlet's current carrying wires to feed both sides of the panel, probably with the third pin attached to the neutral buss bar in the breaker box (although attaching it to the ground buss bar would have identical results).
The lack of electrical knowledge demonstrated in using an outlet to backfeed a generator into a house indicates that the lack of electrical knowledge could cause a 3 wire outlet to be used, and wired as 2 hots and a neutral (or ground). Of course, the RV expected to see 1 hot, 1 neutral, and a ground.
Now, he had a 30 amp 240v outlet wired up, and hooked his 30 amp 120v RV to it, with predictable results.
