ArrowShooter wrote:
Hi Everybody,
Yesterday I changed the spark plug in my Onan and I then poured a can of Sea Foam in the gas tank of the Minnie, 55 gallon tank is half full (28 gallons?)! I then realized I need to get the Minnie in for a smog test! Will the Sea Foam mess me up? Anyone out there have an experience they would like to share?
Regards,
Norm
I would fill it up to dilute the Seafoam IF gas and if fuel injected. I used some and it worked to good, I'm still changing fuel filter every 3,000 miles as it is still freeing up junk in tank and pushing it to gas fuel injector. On the good side I can change an injector and fuel filter in less than 20 min.
I wouldn't worry about smog test to much. Don't you get to fail once before they extract more money out of you?
Side note...Ran some in Coleman lantern, it worked better after that IMO. I will not use it anymore on anything fuel injected, anything carb'd is free game.
Next time you do your generator pick up some hose at Home Depot and run gen off lawn mower gas can with Seafoam mixed in.
