kmb1966
Dec 22, 2018Explorer
jmtandem wrote:I recently had 6 new tires mounted on my motorhome. The shop had alot of white ash/dust all over and it got all over my new tires, so I came home and tried to wash it off. I tried some soap and it didn't clean it off very well, so without 'thinking', I grabbed my Husky electric 1500 psi pressure washer, and washed the tires. Now, I didn't put it on the stream/bead or anything like that, but I did have it on the fan spray mode, and admittedly sprayed it around and around to get this dirt/ash off of the new tires. Now, I'm hearing that wasn't such a great idea. Now I'm concerned if I somehow ruined my tires. Does anyone use a small electric pressure washer? Did I ruin these new tires?
If you did not use chemicals that are detrimental to the tires, you should be good to go.
No, I just used the water hose connected to the electric pressure washer. I used plain soap and water
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
