johnhicks
Oct 19, 2020Explorer II
You won't hurt anything using dielectric grease or cosmoline but won't help anything either. Deoxit works for cleaning but won't help if the socket is burned or mechanically compromised.
Turn off loads and pull the CG breaker when plugging in or unplugging.
When a CG socket gets burned and loose there's nothing you can do about it. If there's a 50A socket available use a dogbone and plug into it
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
