Axledragger's avatar
Axledragger
Diesel engine hard to start. But runs great.HELP
I have an airstream motorhome with a Cummins diesel type C engine with only 45000 miles. I have never had a starting issue. Now It only has a problem at cold start (67 degrees) after that it starts right up and acts like it is getting plenty of fuel. I checked for fuel leaks at the injectors which looked dry, change fuel filter and fuel/water filter. I have a good charge on the battery’s which turn over very fast. Every time I try to leave campground, I run the starter for 3 times for 1 minute, then it starts. Anyone have had this problem please tell me what it needed to fix it.
  • I had a Ford that started to be hard to start when cold and it turned out to be the glow plug relay went bad.
  • 3_tons's avatar
    3_tons
    Explorer III
    Maybe theres a fault with the grid heater (??)...Try turning on the headlights, they should dim during pre-heat...
  • I have an airstream motor home with a Cummins diesel type C engine with only 45000 miles. I have never had a starting issue. Now It only has a problem at cold start (67 degrees) after that it starts right up and acts like it is getting plenty of fuel. I checked for fuel leaks at the injectors which looked dry, change fuel filter and fuel/water filter. I have a good charge on the battery’s which turn over very fast. Every time I try to leave campground, I run the starter for 3 times for 1 minute, then it starts. Anyone have had this problem please tell me what it needed to fix it.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
