Jarlaxle
May 10, 2021Explorer II
ScottG wrote:
Run. As is so often the case with diesels, that shop doesn't know how to diagnose so they claim they need to do everything. Find a better shop.
BTW, is is VERY obvious when an eng is dusted. Also, a leak in the boost lines of a turbo WILL NOT cause dirt ingestion. To the contrary, it pushes air outward.
I would just fix the fan and try again. I bet all is good then.
This...though I will note a boost leak CAN cause damage from excessive EGTs.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
