We bought a new Motor Home with a Diesel engine in it. The question I have, we are at a park for the winter and I was wondering if I can run the engine for 15 minutes while parked, with the 50 amp pow...
Why would you want to do that? You can run it that long, and it doesn't matter if you're plugged into shore power as your transfer switch will disconnect and make the engine's alternator primary. Depending upon the make/model, the slides and levelers may present a problem.
Again, why?
Ron
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
