ol_Bombero-JC
Jul 26, 2018Explorer
Dick_B wrote:
How cool is cool? Did the A/C EVER keep it cool enough? Is the A/C working efficiently, ie? Fins clean, filter clean. Assuming it is ducted does the air come out of each vent the same amount?
We use a fan all the time.
As above.......
Check to see if your A/C is working properly - cooling output.
Buy an air conditioner testing thermometer. Looks like a meat thermometer. It's placed (inserted) in a/the discharge vent.
(Cheap - any auto parts store).
You should get about 20 degrees lower than outside temp.
(You can test the tester by doing same on your auto A/C).
:C
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
