pnichols
Jul 26, 2018Explorer II
ol Bombero-JC wrote:
You should get about 20 degrees lower than outside temp.
I believe that's a common misconception about what to look for in a properly operating an air conditioner.
A properly operating air conditioner's output air temperature should read about 20 degrees lower than it's input air temperature.
Since an RV's air conditioner only recirculates air inside the RV and doesn't actually bring in "new air" from the outside (unless there's a leak in it's ducting somewhere), the air inside the RV is supposed to get colder and colder until the inside air temperature reaches what one sets on it's control.
HOWEVER ... if the cooling capacity of the RV's air conditioner isn't enough to swamp out the amount of heat gain of the RV from the outside (through windows, poorly insulated ceilings and walls, etc.), the air conditioner just keeps running and running trying to get the inside air temperature down to what is set on it's control.
All the while this is happening, a properly operating air conditioner's output air temperature should read 20 degrees lower than it's input air temperature. It's just that the inside air temperature (temperature of the input air to the air conditioner) is constantly getting heated faster from the outside than what the air conditioner can cool - capacity-wise ... so the setting on the control is never reached.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
