wa8yxm
Jul 31, 2018Explorer III
Let's see 15000-13500 = 1500 or 10% of the 15000 So it WILL make a difference, but you may need test equipment to find out how much (you won't notice it)
I do however recommend the upgrade on a "Burned out Bulb" basis.. When my A/C's failed I went from 13,5K to 15K. on the rear one this did NOT increase the power draw (but it is harder to start. fixing soon) the front one I draw 0.8 amps more again way less than 10% difference.
My front is a Coleman. works great Back is Advent Air. not so easy to work on but .. Well that's the hard to start one.. The fan blew up and I put a coleman fan in it so it sucks now instead of blows (makes it easier to clean the condenser).
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
