path1's avatar
path1
Difference in honda generators Big store vs small dealer?
Pricing out Honda 2000's. Overall big box store $200 less than Honda dealer. Any reason? Honda's part numbers from their on line site has 3 different part numbers for their 2000I.
EU2000iT1A1, EU2000I1A1, EU2000IKN, EU2000IKC
Is there any difference from one or the other?
  • I do not believe that there are different versions of Honda generators for different retailers.
  • Johno02 wrote:
    Products are made especially to sel at a discount in the big box stores. Looks the same, sounds the same, but they cut corners somewhere to make it cheaper. And, there are different ones for the different stores, so that you can't match between them.
    Interesting, I didn't know they made different units for each store.
    It seems like it would be counter productive.
  • And I believe the California Carb Compliant has its own part number as well.
  • I didnt have much luck looking up those numbers.
    They make a companion version which has a 30A recep on it.
    They also have a camo version.
    And an OSHA compliant which looks like its GFI only.
  • You will not find much of a price difference the prices are fixed by Honda. The only difference may be service if you were to need it which may be better at a small shop. Parts are available on line. I have three of the 2000I's one of which is the companion model all were purchased on line and have never needed any service that I could not do myself such as oil changes and cleaning the air filter , changing the spark plug also changed one carb and one muffler , over 12 years of using them. Great machines
    Mike
  • Products are made especially to sel at a discount in the big box stores. Looks the same, sounds the same, but they cut corners somewhere to make it cheaper. And, there are different ones for the different stores, so that you can't match between them.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
