Huntindog wrote:
As has been said many times. When ordering from China just get one at first to see if you like it. If you do, then order what you want.
Exactly. I ordered several different bulbs until I found the ones I like. If their specs are correct, a 250-300 Lumins bulb should be a good replacement for an incandescent interior pancake light.
I found the "Gold Stars" brand 280 Lumins LEDs on ebay worked very well and used them throughout my last camper with no failures. I just replaced all the lamps in my new camper with them. I can run 8 to 10 of them at once for about the same power draw as one incandescent. Big battery savings when boondocking and they don't generate heat.
Make sure any you buy are not just 12 volts. Anything made for an RV should have a working voltage range of a minimum 10 to 24 volts.
