cdcorpe wrote:
Thanks , what should I look for in volts & amps, & the time for each the next time I run it down to 50%?
Same pattern as I posted earlier for my PM3 100amper, except for 75 amps on 232AH instead of 100amps on 458AH. You will still get that drop to 13.6 at about 70% SOC. Times will be similar to those in the 70amp on 220AH plot I posted earlier
When camping recharging by generator, just do 50-80s so you only do the 70-80 at the slower 13.6v. Even better, if you have solar going strong that day, just do a 50-70 on generator and shut off the gen when it drops to 13.6 from 14.8 then go on solar.
