Eyehi's avatar
Eyehi
Digital thermostat
Hello everyone i was having a thermostat problem with my cougar 5 th wheel trailer last fall ( the furnace would not stop running) so i installed a digital thermostat..... The furnace worked great but my ac will not run.....would anyone have any advice on how to properly wire the thermostat so the ac will work ? The dometic thermostat was wired as follows
Red wire - 7.5
Yellow wire- cool
White wire -furnace
Blue wire - hi fan
Orange wire - fan
Black wire - ground
Here is the wiring on the new thermostat
Thanks in advance for the help
  • Usually the hi fan is the wire you don't hook up. Try hooking up the low fan.
    We're all assuming you've read the instruction sheet!
  • You either need to hook a wire to Rc or jump a wire from Rh to Rc. Rh is for heating Rc is for cooling.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
