- pianotunaNomad IIIHi Matt,
The battery is not totally dead--but it only goes "click" when I turn the key. I solved the issue on the trip back north by getting a "jump pack".
The last Walmart I stopped at had a battery whose dimensions fit the Yamaha. - MattFLExplorer
pianotuna wrote:
Hi,
Does anyone know the dimensions of the Yamaha 3000 iSEB battery? The weather in Florida "ate" mine and I'm beating my way back to Canada.
Did you run your generator without the battery for any length of time, and did it cause any trouble if you did? I've got the same generator with a bad battery and trying to determine if it's OK (won't cause damage) to run without it. - ScottGNomad
pianotuna wrote:
Hi Scott,
Thank you!
:C - pianotunaNomad IIIHi Scott,
Thank you! - ScottGNomad
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
