MEXICOWANDERER's avatar
Sep 29, 2017
DIN? (School Is In) Nerd Fodder
What Does DIN Stand For?
DIN stands for ‘Deutsches Institut für Normung’ which means ‘German Institute of Standardization’. DIN develops norms and standards as a service to industry, to the state and to society as a whole. It is a registered non profit organization which has been based in Berlin since 1917. It consists of nearly 1,700 members who include individual companies, associations, public authorities, and other organizations from industry, commerce, the trades and research. DIN members support standardization through membership fees and play an active part in the decision making process.
DIN develops standards which lay down general or detailed specifications for products, procedures and services. The DIN EN 45020 defines the term “standard” as a “document, established by consensus and approved by a recognized body that provides, for common and repeated use, rules, guidelines or characteristics for activities or their results, aimed at the achievement of the optimum degree of order in a given context”. Anyone can submit a proposal for a new standard. Once a proposal has been accepted, a standardization project involves all interested parties, who delegate experts to represent their interests in the work groups overseen by DIN’s Standards Committee.
DIN Standards are consensus based and hence work groups need to arrive at a common standpoint. Developing a standard involves research on technological developments, economic viability and international harmonization. Once discussion has reached the stage of initial agreement, the results are published as a draft and made available to the general public for comment. Comments received are reviewed by the Standards Committee before the standard is finally published.What Does DIN Stand For?
DIN develops standards for virtually every field of product manufacture and development. For example DIN 55561 specifies requirements relating to the use of Braille on packaging. The DIN EN 748 lays down the dimensions, materials and designs for football pitches. The construction and performance of automatic nozzles on fuel dispensers for cars, boats and aircrafts is described in the DIN EN 13012. The physical properties of manual toothbrushes are the subject of the DIN EN ISO 20126 and the DIN 1451 describes the sans-serif typeface that is widely used for administrative and business applications.
What do abbreviations at the beginning of a standards number mean?
DIN: German standard developed solely at national level that has primarily national significance. It may also be the preliminary version of a future supranational document.
DIN EN: European Standard that has been published, unchanged, in Germany.
DIN EN ISO: Increasingly, standards are developed either under the leadership of ISO (International Organization of Standardization) or of CEN (European Committee for Standardization) and then published by both organizations. In Germany these are published as “DIN EN ISOs”.
DIN ISO: ISO standard adopted unchanged as a German Standard.
DIN IEC: IEC (International Electrotechnical Commission) standard adopted unchanged as a German Standard.
  • Remember when the USA used to be the world leader in technology and standards? I helped institute ISO 2000 in my work place. It was all about paper work. Didn't improve the quality of any thing. Wouldn't it be great if we were leaders again and not followers.
    Richard
  • My welder uses DIN standard connectors for the cables. That means I can buy cables from anyone who follows the DIN standard. Cool!
  • j-d's avatar
    j-d
    Explorer II
    DIN makes choosing and installing Car Stereo units a lot easier than it used to be! In "late models" I've even found the wiring colors match. I learned quick that
    DIN or Single DIN - the common small units
    Many fancy units are Double DIN - same width, twice as "tall"
    Some diabolical manufacturers like Ford - 1.5 DIN - Don't buy that fancy Double DIN without a SawzAll and room to use it!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
