stevenal
Jul 19, 2023Nomad III
wa8yxm wrote:
Not only would it prevent a stronger battery from charging a weaker battery
It would prevent the converter from doing so as well.. No valid reason for doing that.
I would expect the converter negative lead to be between the two diodes. The voltage drop across the diodes will prevent the converter from fully charging the batteries, though, unless the converter has been adjusted to a higher voltage.
